![Sequence Diagram – Selection and Loops in a Combination](https://circle.visual-paradigm.com/wp-content/uploads/2017/08/Sequence-Diagram-Selection-and-Loops-in-a-Combination.png)
This is a sequence diagram that shows the representation of selection and loop.
frame: box around part of diagram to indicate if or loop
- if -> (opt) [condition]
- if/else -> (alt) [condition], separated by horizontal dashed line
- loop -> (loop) [condition or items to loop over]
In this example:
For each of the line item in the order - if the item value > 10,000 then dispatch through careful Distributor, else dispatch through regular distributor.
If any items fall into “needsConfirmation” condition the confirm message will be sent to the messenger.
Import into your Project
Open diagram in Visual Paradigm [?]Copy the URL below, paste it in the Open Project windows of Visual Paradigm and press Enter to open it |
Posted by: Shirley Langley
