If you want to remove Visual Paradigm from your system, you can perform an uninstallation.
To perform uninstallation of Visual Paradigm, the uninstaller will remove the Visual Paradigm installation folder and its containing files from the system. If your installation was previously performed by the Installer, you can uninstall it by running the uninstall executable file right under the installation directory. If it was installed by decompressing the zip file that contains the pre-packed installation using the Install-Free version package, you simply need to delete the whole installation folder to have Visual Paradigm removed.
Note that: uninstallation procedure will not automatically remove the setting files (such as licensing information, custom settings, end, etc.) that are stored under the Home directory. (So that the settings can be restored in the further reinstallation of Visual Paradigm)
