Chapter 26. IDE Integration
⌘K
  1. Home
  2. Docs
  3. Chapter 26. IDE Integrati...
  4. 5. Android Studio Integra...
  5. How to integrate Visual Paradigm with Android Studio
Visual Paradigm enables you to integrate the visual modeling environment with Android Studio, providing full software development life cycle support. By designing your software system in Visual Paradigm, you can generate programming source code from class diagram to an Android Studio project. Also, you can reverse engineer your source code into class models in Visual Paradigm.
Installation
To install Android Studio Integration from Visual Paradigm:
  1. In Visual Paradigm, select Window > Integration > IDE Integration… from the toolbar.
  2. Select IntelliJ IDEA / Android Studio Integration. You can run Visual Paradigm in multiple IDEs. In other words, if you need you can select multiple IDEs here. Click Next.
    Select 'IntelliJ IDEA / Android Studio Integration"
  3. Specify the folder path of Android Studio. Click Next to start copying files to your IDE.
    Specifying path of Android Studio
Notes:
  1. Android Studio integration can only be installed on one Android Studio directory only.
  2. The installation process will modify/add files under your IDE installation directory. For Windows user, you may need to run Visual Paradigm as administrator in order to allow it to run through the installation process with the required permission. To run Visual Paradigm as administrator, right click on its executable in the bin folder or its shortcut and select Run as Administrator to start it up.
Un-Installation
To remove the installation with an integrated IDE, perform an uninstallation.
  2. Select the radio button Uninstall.
  3. Select IntelliJ IDEA / Android Studio Integration.
    Select IDE to uninstall
  4. Click Next.
  5. Click Next for file removal.
