Chapter 26. IDE Integration
⌘K
  1. Home
  2. Docs
  3. Chapter 26. IDE Integrati...
  4. 4. IntelliJ IDEA Integrat...
  5. How to select source code in IntelliJ IDEA from UML
Once a UML class is associated with a Java source by code reversal/generation, you can select from UML class the corresponding Java source file in IntelliJ IDEA.
Selecting Java Source from UML Class
To open a Java source file from a UML class, right-click on the UML class in Diagram Navigator/Model Explorer/Class Repository or in diagram and select Select in Code from the popup menu. This opens the corresponding source file in code editor.
Select source file from UML class
