Chapter 37. MODAF Tool
⌘K
  1. Home
  2. Docs
  3. Chapter 37. MODAF Tool
  4. 4. Operational Viewpoint
  5. OV-1a – High-Level Operational Concept Graphic
The OV-1a provides a graphical view of what the architecture is addressing and an idea of the players and operations involved. Its main use is to aid human communication, and it is intended for presentation to high-level decision-makers.
The OV-1a provides a graphical, scenario-based, description of a mission or class of mission could fulfil a business objective. It shows the main nodes and interesting or unique aspects of operations. It describes the interactions between the subject architecture and its environment (including external systems), in order to convey the right amount of information to stakeholders. Its main utility is to communicate the purpose of the architecture to non-technical, high-level decision-makers.
Unlike an OV-2, an OV-1a may show elements of the solution (physical) architecture – in other words, OV-1a is not strictly speaking a logical view.
Usage
The intended usage of the OV-1a includes:
  • Puts an operational situation or scenario into context.
  • Provides a tool for discussion and presentation; for example, aids industry engagement in an acquisition.
  • Provides an overview of more detailed information in published architectures.
Product Description
The OV-1a provides a graphical executive summary of the architectural endeavour, which describes the interactions between the subject architecture and its environment, and between the architecture and external systems. A textual description accompanying the graphic is essential, with labels on the graphic and a detailed description in the OV-1b. Graphics alone are not sufficient for capturing the necessary architecture data.
The purpose of OV-1a is to provide a quick, high-level description of the business objective that the architecture is addressing, and how that objective might be achieved. An OV-1a can be used to orient and focus on detailed discussions. Its main utility is to communicate the purpose of the architecture to non-technical, high-level decision-makers.
Creating a High-Level Operational Concept Graphic
To create a High-Level Operational Concept Graphic:
  1. Click on High-Level Operational Concept Graphic in the Action Artifact area, and then select Create New Diagram.
  2. Type the diagram name and press Enter.
  3. A blank diagram is created and you can start constructing the view. You can use Image shape to represent concepts and connect them with Generic Connectors.
MODAF Example: High-Level Operational Concept Graphic
MODAF in Visual Paradigm
The MODAF is brought to you by Visual Paradigm, a full-featured development platform. Visual Paradigm provides an easy-to-use, model-driven MODAF tool that supports the development of MODAF views and models. You can create integrated MODAF products and generate architectural documents that facilitate organizations to efficiently coordinate enterprise architecture initiatives.
