Chapter 37. MODAF Tool
⌘K
  1. Home
  2. Docs
  3. Chapter 37. MODAF Tool
  4. 5. System Viewpoint
  5. SV-11 – Physical Schema
The SV-11 defines the structure of the various kinds of system data that are utilised by the systems in the architecture.
The SV-11 provides an implementation specific data model that realises the logical data model presented in an OV-7, Information Model.
Implementation constraints may mean that one logical entity in OV-7 is in fact realised by more than one entity in SV-11 and vice versa.
Usage
The intended usage of the SV-11 includes:
  • Specifying the system data elements exchanged between systems (thus reducing the risk of interoperability errors).
  • Definition of physical data structure (input to system design).
Product Description
SV-11 allows implementation-level detail of data structures to be modelled. The view serves several purposes, including:
  • Providing the detailed information on the system data elements exchanged between systems, thus reducing the risk of interfacing errors.
  • Providing system data structures for use in the system design process, if necessary.
SV-11 is an implementation-oriented data model that is used to describe how the information requirements represented in OV-7 are actually implemented for a given solution. The entities specified in SV-11 represent data elements (from the SV-6, Systems Data Exchange Matrix).
Standards associated with entities are also often identified in the development of the SV-11 view product; these should be recorded in the TV-1 Standards Profile.
Creating a Physical Schema diagram
To create a Physical Schema diagram:
  1. Click on Physical Schema in the Action Artifact area, and then select Create New Diagram.
  2. Type the diagram name and press Enter.
  3. A blank diagram is created and you can start constructing the view. You can create DataElements and/or InformationElements. Connect elements with Associations.
MODAF Example: Physical Schema
MODAF in Visual Paradigm
The MODAF is brought to you by Visual Paradigm, a full-featured development platform. Visual Paradigm provides an easy-to-use, model-driven MODAF tool that supports the development of MODAF views and models. You can create integrated MODAF products and generate architectural documents that facilitate organizations to efficiently coordinate enterprise architecture initiatives.
