| .NET |
- Not specified – (default) Do not specify whether Instant Reverse of .NET is enabled or not.
- Enabled – Enable Instant Reverse for .NET
- Disabled – Disable Instant Reverse for .NET
| C++ |
- Not specified – (default) Do not specify whether Instant Reverse of C++ is enabled or not.
- Enabled – Enable Instant Reverse for C++
- Disabled – Disable Instant Reverse for C++
| Text File Encoding |
- System default – (default) The default system encoding will be selected as encoding for source files that will be reversed
- Other – Specify an encoding for the source files that will be reversed
| Show Instant Reverse Form Diagram dialog after Instant Reverse |
(default true) Show the Instant Reverse Form Diagram dialog box after Instant Reverse, so that you can form diagram after reversing code into Visual Paradigm. |
