A user path is a variable that refers to a base path in user’s computer. You can add a reference to local file using user path so that the reference refers to a file relative to a user path, instead of an absolute path. This means you can move references files to a different location, or even to a different computer, and can still open them as long as the user path value is up-to-date.
| Option Name | Description |
| Show user path | (default false) Select to show user paths in references, instead of displaying resolved absolute paths. A user path is displayed with its name enclosed by ${ }. |
| Prompt to specify user path | (default false) When adding a reference comprises a path that is not defined as a user path, you will be prompted to add path as user path. |
