| Class declaration |
Same line – (default) Brace for class declaration appears at the same line as the declarationNext line – Brace for class declaration appears at the line after the declaration |
| Constructor declaration |
Same line – (default) Brace for constructor appears at the same line as the declarationNext line – Brace for constructor appears at the line after the declaration |
| Method declaration |
Same line – (default) Brace for method appears at the same line as the declarationNext line – Brace for method appears at the line after the declaration |
| Enum declaration |
Same line – (default) Brace for enumeration appears at the same line as the declarationNext line – Brace for enumeration to appear at the line after the declaration |
| Annotation type declaration |
Same line – (default) Brace for annotation type appears at the same line as the declarationNext line – Brace for annotation type appears at the line after the declaration |
| Indentation policy |
Tabs – (default) Use a tab of space as indentationSpaces – Use spaces as indentation. The number of spaces can be defined below |
| Indentation size | The number of spaces to indent. |
