1. Home
  2. Docs
  3. Chapter 30. Project Options
  4. 4. State Code Engine
  5. State Code Engine
State Code Engine
Download PDF
Option Name Description
Language you can select the following language:
  • Java – (default) Generate code in Java
  • C# – Generate code in C#
  • VB .NET – Generate code in VB.NET
  • C++ – Generate code in C++
Synchronized transition methods (default true) Generate synchronized keyword for transition methods.
Auto create transition methods (default true) Auto generate operation to owner class by transition.
Re-generate transition methods (default false) Overwrite the transition methods if already exists in source code.
Generate try catch block (default true) Generate try catch block for method calls that may produce exception.
Generate debug messages (default false) Generate debug message to help tracing problems that happen when running generated code.
Generate sample code (default true) Generate sample code to help you to understand how to work with generated code.
