What is Code Engineering
Visual Paradigm code engineering provides a powerful, and yet intuitive graphical interface for forwarding UML models to programming languages, as well as reversing code back to UML model for documentation. Here is some popular use cases for coding engineering:
Java Round-Trip Engineering
Generate Java source code from UML class model, and let the UML model reflect the change you made in source code. Round-trip engineering helps keep your Java source code and software design synchronized. Every time you generate code or update UML model, changes will be merged.
REST Code & Documentation Publisher
Generate executable Java code and HTML documentation for you to get started with RESTful API development. Both back-end development and client side consumption are supported and benefited by the HTML documentation and visual communication model generated.
Run in IDE
No switching applications, no hassle! Design and implement software within a single environment – your favorite IDE. With the UML editor seamlessly integrated into the IDE, you can focus on developing your great software comfortably. Just click once to update your code from UML design, click again to have your UML class model updated base on the source code.
Form Sequence Diagram from Java Code Logic
Study the runtime behavior of an application by mean of a UML sequence diagram. Visual Paradigm supports the reverse engineering of sequence diagram from Java source code.
Range of supported languages
C#, Java, DLL, .NET, VB.NET, PHP, Python, XSD, XML, ActionScript, Objective-C, Ada95, ODL, IDL, Delphi, PERL & Ruby
State machine code generation
Model controller class and its state machine with class diagram and state machine diagram, and generate the source code for the state machine.
Export state machine diagram to SCXML
Export State Chart XML (SCXML) from state machine diagram.
Articles
- 1. Instant Reverse
- How to generate UML from Java sources and classes
- How to generate UML from C#
- How to generate UML from C++
- How to generate UML from .NET DLL and .exe files
- How to generate UML from CORBA IDL
- How to generate UML from Ada 9x
- How to generate UML from XML
- How to generate UML from XML Schema (XSD)
- How to generate UML from Hibernate Mapping
- How to generate UML from PHP 5.0
- How to generate UML from Python
- How to generate UML from Objective-C
- How to generate UML Sequence Diagram from Java
- 2. Instant Generator
- How to generate Java from UML
- How to generate C# from UML
- How to generate VB.NET from UML
- How to generate PHP from UML
- How to generate ODL from UML
- How to generate ActionScript from UML
- How to generate IDL from UML
- How to generate C++ from UML
- How to generate Delphi from UML
- How to generate Perl from UML
- How to generate XML Schema (XSD) from UML
- How to generate Python from UML
- How to generate Objective-C from UML
- How to generate Objective-C 2.0 from UML
- How to generate Ada95 from UML
- How to generate Ruby from UML
- How to customize code generation template
- 3. Java Round-Trip
- 4. C++ Round-Trip
- 5. Object Relational Mapping
- 6. Reverse ORM POJO Classes
- 7. State Machine Diagram Generation
- 8. Rest API Design and Generation
