Chapter 25. Code Engineering
⌘K
  1. Home
  2. Docs
  3. Chapter 25. Code Engineer...
  4. 2. Instant Generator
  5. How to customize code generation template
Instant Generator allows you to generate programming source code from UML class model. Basically, the content of the generated code follows the common coding convention of the programming language. There are also advanced options for you to configure some of the specific settings in forming the code, like the use of prefix for attributes and parameters.
Although the built-in way of generating source code can satisfy most of the general needs, you may want to define something more specific. For example, you may need to print a copyright statement at the beginning of the code file, which is not a kind of customization being supported by Instant generator.
Fortunately, the way of how source code will be generated is handled by Apache Velocity engine, a templating engine, and the templates being used are fully opened for customization. In the following sections, we will explain how to customize a template to make the generated code follow your requirement.
Setting up development environment
The template files are put under the resources/instantgenerator folder of Visual Paradigm installation directory. It is absolutely alright to edit those files directly. However, it is recommended to setup your own development environment, copy the template files to there to perform further editing. There are two reasons for separating the development environment from Visual Paradigm:
  • Avoid the unexpected template removal by un-installing the Visual Paradigm.
  • Avoid accidental file replacement by running product updates.
To setup your development environment:
  1. Create a folder as working directory.
  2. Explore %Visual-Paradigm-Installation-Directory%/resources/instantgenerator.
  3. You will see a number of sub-folders that have the programming language as their names. Each of them contains the templates files for a specific programming language. Copy the folder(s) of the language(s) you need to customize and paste to the working directory.
Customizing template
By having the text editor and the development environment ready, it’s time to get your hand dirty with editing the template. As mentioned before, Instant generator adopted the Apache Velocity engine in generating source code. For those who are interested in knowing how to write templates, please read Velocity’s Users’ guide at:
http://velocity.apache.org/engine/releases/velocity-1.5/user-guide.html.
The following example demonstrates how to edit the PHP code generation template to reposition the brace of operation blocks to a new line.
Customization of operation in PHP class
  1. Open the template you need to edit in text editor.
    Open PhpOperation.vm in text editor
    At the beginning, you may find the template a bit complex. But once you start working on it for a while, you’ll find the syntax easy to understanding. In fact, it just composes of common programming construct like if-then-else statements, foreach and variables that programmers should find intuitive.
  2. Look for the area that you need to edit.
    Search for the open branch
  3. Make change.
    Insert line breaks
  4. Add a variable $indentation to indicate the need of printing indentation before the open brace.
    Add variable
  5. Save the file.
Generate code with the customized template
To generate code with customized template:
  1. In Visual Paradigm, select Tools > Code > Instant Generator from the toolbar, then the programming language that have the template customized.
  2. Specify the Template directory where the customized templates are stored.
    Specifying template directory
  3. Select the classes to generate. Specify the output path. Click Generate to generate code. You may refer to previous chapters for details about instant generator.
List of API calls
The following table lists the available API calls for retrieving data from models.
Class API Return Value
Annotation commentArray() Comment[]
commentAt(int) Comment
commentCount() int
commentIterator() Iterator
getDocumentation() String
getName() String
getStereotype(String) Stereotype
getStereotypeIgnoreCase(String) Stereotype
getTaggedValue(String) TaggedValue
getTaggedValueIgnoreCase(String) TaggedValue
hasStereotype(String) boolean
hasStereotypeIgnoreCase(String) boolean
hasTaggedValue(String) boolean
hasTaggedValueIgnoreCase(String) boolean
isFromLinkedProject() boolean
propertyArray() Object[]
propertyAt(int) AnnotationProperty
propertyCount() int
propertyIterator() Iterator
stereotypeArray() Stereotype[]
stereotypeAt(int) Stereotype
stereotypeCount() int
stereotypeIterator() Iterator
taggedValueArray() TaggedValue[]
taggedValueAt(int) TaggedValue
taggedValueCount() int
taggedValueIterator() Iterator
AnnotationProperty commentArray() Comment[]
commentCount() int
getName() String
getValue() String
Association associationClassArray() AssociationClass[]
associationClassAt(int) AssociationClass
associationClassCount() int
associationClassIterator() Iterator
commentCount() int
fromAssociationClassArray() Object[]
fromAssociationClassAt(int) AssociationClass
fromAssociationClassCount() int
fromAssociationClassIterator() Iterator
getFromElement() Object
getFromEnd() AssociationEnd
getName() String
getToElement() Object
getToEnd() AssociationEnd
isAbstract() boolean
isDerived() boolean
isLeaf() boolean
toAssociationClassArray() Object[]
toAssociationClassAt(int) AssociationClass
toAssociationClassCount() int
toAssociationClassIterator() Iterator
AssociationClass commentArray() Comment[]
commentCount() int
getName() String
getVisibility() String
AssociationEnd commentArray() Comment[]
commentCount() int
getAggregationKind() String
getMultiplicity() String
getName() String
getNavigable() int
getReferencedAttribute() Attribute
getTypeModifier() String
isOrdered() boolean
isProvideGetterMethod() boolean
isProvideSetterMethod() boolean
isUnique() boolean
Attribute annotationArray() Object[]
annotationAt(int) Annotation
annotationCount() int
annotationIterator() Iterator
commentCount() int
getDeclarativeAttribute() String
getFieldType() Object
getInitialValue() String
getMetadataTag() String
getName() String
getScope() String
getStorage() int
getTemplateTypeBindInfo() TemplateTypeBindInfo
getType()
getXmlSchemaFieldType() Object
hasGetter() boolean
hasSetter() boolean
hasXmlSchema() boolean
isConst() boolean
isDefault() boolean
isExtern() boolean
isFinal() boolean
isHasGetter() boolean
isHasSetter() boolean
isIndexer() boolean
isNew() boolean
isOrdered() boolean
isOverload() boolean
isOverride() boolean
isReadonly() boolean
isShadow() boolean
isTransient() boolean
isUnique() boolean
isUnsafe() boolean
isVirtual() boolean
isVisible() boolean
isVolatile() boolean
isWithEvent() boolean
propertyParameterArray() Object[]
propertyParameterAt(int) Parameter
propertyParameterCount() int
propertyParameterIterator() Iterator
AttributeType commentArray() Comment[]
commentCount() int
getFixed() String
getName() String
getUse() String
Class annotationArray() Object[]
associationArray() Association[]
associationAt(int) Association
associationCount() int
associationIterator() Iterator
attributeArray() Attribute[]
attributeAt(int) Attribute
attributeCount() int
attributeIterator() Iterator
commentCount() int
containmentClassArray() Class[]
containmentClassAt(int) Class
containmentClassCount() int
containmentClassIterator() Iterator
fromAssociationArray() Object[]
fromAssociationAt(int) Association
fromAssociationCount() int
fromAssociationIterator() Iterator
generalizationArray() Generalization[]
generalizationAt(int) Generalization
generalizationCount() int
generalizationIterator() Iterator
getManageType() int
getName() String
getType() Object
isActive() boolean
isFinal() boolean
isInterface() boolean
isLeaf() boolean
isNew() boolean
isNotInheritable() boolean
isRoot() boolean
isSealed() boolean
isShadow() boolean
isStatic() boolean
isStereotypeInterface() boolean
isStereotypeTypedef() boolean
isTypedef() boolean
operationArray() Operation[]
operationAt(int) Operation
operationCount() int
operationIterator() Iterator
realizationArray() Realization[]
realizationAt(int) Realization
realizationClassArray() Object[]
realizationClassAt(int) Class
realizationClassCount() int
realizationClassIterator() Iterator
realizationCount() int
realizationIterator() Iterator
templateParameterArray() TemplateParameter[]
templateParameterAt(int) TemplateParameter
templateParameterCount() int
templateParameterIterator() Iterator
toAssociationArray() Object[]
toAssociationAt(int) Association
toAssociationCount() int
toAssociationIterator() Iterator
Comment commentCount() int
getAuthor() String
getContent() String
getDateTime() String
getName() String
getSummary() String
DataType commentArray() Comment[]
commentCount() int
getName() String
templateParameterArray() Object[]
ElementType commentArray() Comment[]
commentCount() int
getBlock() String
getForm() String
getName() String
getNillable() String
Generalization commentArray() Comment[]
commentCount() int
getName() String
isSubstitutable() boolean
ImplModel commentArray() Comment[]
commentCount() int
getCode() String
getName() String
Object commentArray() Comment[]
commentCount() int
getName() String
Operation annotationArray() Object[]
commentCount() int
getAlias() String
getCharset() int
getDllName() String
getImplModel() ImplModel
getMethodKind() int
getName() String
getOperatorType() int
getProcedureName() String
getReturnType() Object
getReturnTypeDocumentation() String
getReturnTypeModifier() String
getScope() String
isConst() boolean
isDeclare() boolean
isDelegate() boolean
isExtern() boolean
isFinal() boolean
isFriend() boolean
isInline() boolean
isNative() boolean
isNew() boolean
isNotOverridable() boolean
isOverridable() boolean
isQuery() boolean
isReturnTypeConst() boolean
isSealed() boolean
isShadow() boolean
isSynchronized() boolean
isUnsafe() boolean
isVirtual() boolean
isVisible() boolean
parameterArray() Object[]
parameterAt(int) Parameter
parameterCount() int
parameterIterator() Iterator
postConditionArray() Object[]
postConditionAt(int) Text
postConditionCount() int
postConditionIterator() Iterator
preConditionArray() Object[]
preConditionAt(int) Text
preConditionCount() int
preConditionIterator() Iterator
raisedExceptionArray() Object[]
raisedExceptionAt(int) Object
raisedExceptionCount() int
raisedExceptionIterator() Iterator
Package classArray() Class[]
classAt(int) Class
classCount() int
classIterator() Iterator
commentCount() int
getName() String
packageArray() Object[]
packageAt(int) Package
packageCount() int
packageIterator() Iterator
Parameter annotationArray() Object[]
commentCount() int
getDefaultValue() String
getDirection() String
getName() String
getType() Object
isConst() boolean
isFinal() boolean
isOptional() boolean
isParamArray() boolean
isParams() boolean
Realization commentArray() Comment[]
commentCount() int
getMapping() String
getName() String
Stereotype commentArray() Comment[]
commentCount() int
getName() String
TaggedValue commentArray() Comment[]
commentCount() int
getName() String
getType() int
getValue() Object
TemplateParameter commentArray() Comment[]
commentCount() int
getName() String
templateTypeBindInfoArray() Object[]
templateTypeBindInfoAt(int) TemplateTypeBindInfo
templateTypeBindInfoCount() int
templateTypeBindInfoIterator() Iterator
typeArray() Object[]
typeAt(int) Object
typeCount() int
typeModifierArray() Object[]
typeModifierAt(int) String
typeModifierCount() int
typeModifierIterator() Iterator
TemplateTypeBindDetails commentArray() Comment[]
commentCount() int
getArguments() TemplateTypeBindInfo
getName() String
getWildcard() int
TemplateTypeBindInfo commentArray() Comment[]
commentCount() int
detailsArray() Object[]
detailsAt(int) TemplateTypeBindDetails
detailsCount() int
detailsIterator() Iterator
getBindedType() Object
getName() String
Text commentArray() Comment[]
commentCount() int
getName() String
TextType commentArray() Comment[]
commentCount() int
getName() String
Velocity syntax
The following lists the syntax that of statements that can be used in the template.
## ===== If =====
#if(...)
#end
## ===== If-then-Else =====
#if(...)
#else
#end
## ===== For-each =====
#foreach
#end
## ===== Continue with the template defined in (...) at the point where the call is made =====
#parse(...)
#set(...)
## ===== Comment =====
## ===== Variable=====
