Chapter 25. Code Engineering
⌘K
  1. Home
  2. Docs
  3. Chapter 25. Code Engineer...
  4. 2. Instant Generator
  5. How to generate C++ from UML
Instant Generator is the process of producing source code from UML class model. Designers or software architects can build a high level domain class model, then pass to programmer to perform more lower-level system or application modeling and eventually generate source code from implementation model. This chain makes building software faster and cheaper. In this chapter, we will go through the instant generation of C++. To generate code by instant generator:
  1. Select Tools > Code > Instant Generator from the toolbar.
  2. In the Instant Generator window, select C++ as the Language.
  3. Fill in the Output Path, which is the directory where you want the code to generate to.
  4. Select the classes to generate code. In the Diagrams tab, you can select the diagrams to generate code for classes in the selected diagrams. Alternatively, open the Model Elements tab and select the classes to generate code.
    Selecting classes to generate code
  5. Optionally configure the generator options. Read the section below for a description of options.
  6. Click Generate to generate code.
Overview of Instant Generator
Overview of instant generator window
No. Name Description
1 Language The programming language to generate.
2 Model element tree A list of packages and classes that can be selected for code generation. You must select classes for code generation.
3 General options Some of the common configurable options are shown here. You can configure them in advanced options.
4 Output path The folder where you want the code files to be generated.
5 Template directory Template governs how code will be generated from model to code. You can customize the template to suit your needs, such as to print company specific headers to each code file. If you want to use your own template, provide the template directory here. If you want to keep using the build in template, leave this option unchanged to let Visual Paradigm generate with build in template. To learn more about customization, read the final chapter of this part.
6 Advanced options Click this button to configure any options related to code generation in a new window.
7 Prompt to confirm overwrite file If a code file instant generator going to generate is already exist, by checking this option you will be asked whether to overwrite that file or not. If you uncheck this option, it will help you to overwrite the existing file automatically.
8 Output pane Any warning, error or progress about generation will be printed here.
9 Open output folder Open the output path with system browser.
10 Preview Click to preview the code content. It is just a preview and code will not be generated to the output path by previewing.
11 Generate Click to start generation.
12 Close Click to close the instant generator.
Generator options
On the Instant Generator window you can configure some of the common code options at the right of window. You can also configure the advanced options for more detailed settings by clicking the Advanced Options… button.
Advanced Options window
Below is a description of available options.
Option Description
Encoding The encoding of source file.
Attribute prefix The text to append to attribute name as prefix.
Parameter prefix The text to append to parameter name as prefix.
Allow From Linked Project Check to generate also classes in referenced project.
Indentation Character(s) being used for indentation. Default is Tab.
Generate unnamed attribute When two classes are associated, checking this option will generate attributes in both classes with each other as type. When unchecked, attributes will not be generated to both of them.
Unnamed attribute Pattern will be applied when generating name for those attribute without name.
Invalid char replacement Invalid char refers to characters that will result in a compile error when compiling code. This option is for replacing those invalid characters by given one.
Default attribute type Attribute type that will be used when attribute has no type specified.
Default parameter type Parameter type that will be used when parameter has no type specified.
Default operation return type Operation return type that will be used when operation has no return type specified.
Pointer for composition When checked, generate attribute for linking composited class using pointer (by reference).
Implement abstract operations Whether or not to generate operations for implementing abstract operations defined in super class.
Generate association operations If you check this box, when a role is selected to provide setter/getter, the corresponding operation(s) will be generated for the role’s attribute.
Generate simple collection operations Whether or not to generate setter and getter for accessing attribute of associated class, when getter and setter are checked.
Generate additional collection operations Whether or not to generate add, remove and to methods for accessing attribute of associated class, when getter and setter are checked.
Local variable prefix The characters to be appended to local variables.
Association implementation The type of collection to be used for association.
Standard ANSI C++ – Most general standard of C++
Visual C++ – Microsoft enhanced ANSI C++ and develop another standard
Using Template Whether to generate template or not.
Force first attribute character to lower case Force the first character in attribute name to be in lower case.
Force first operation character to lower case Force the first character in operation name to be in lower case.
Force first parameter character to lower case Force the first character in parameter name to be in lower case.
Folder Structure Follow Package Generate folders according to package structure.
Group By Visibility Group class members by their visibility.
