1. Home
  2. Docs
  3. Chapter 5. UML & Req...
  4. 15. CRC Card Diagram
  5. How to create CRC Card Diagram
Class-Responsibility Collaborator (CRC) card visualize classes in card-like presentation. Each CRC card contains information like the description of class, its attributes and responsibility. A CRC card diagram is a holder of these cards.
Creating CRC card diagram
  1. Select Diagram > New from the application toolbar.
  2. In the New Diagram window, select CRC Card Diagram.
  3. Click Next.
  4. Enter the diagram name and description. The Location field enables you to select a model to store the diagram.
  5. Click OK.
Creating CRC card
Click CRC Card on the diagram toolbar and then click on the diagram to create a CRC card. You can create as many as CRC card on a diagram by repeating this step.
Editing CRC card properties
All properties in a CRC card must be edited inline. To edit, double click on the desired field, update its value, and click on the diagram background to confirm editing.
Edit description
Adding attributes
Right-click on the Attributes heading and select Add > Attribute from the pop-up menu.
Enter the name and description. Repeat this step until all attributes are added.
Attribute added
Adding responsibilities
Right-click on the Responsibilities heading and select Add > Responsibility from the pop-up menu. Similar to creating an attribute, enter the name and collaborator of each responsibility to show the relationship with other parties.
Add responsibility
