When your team attempt to or has made significant changes on a document, you may want to record the version of document, the date/time when the change took place, the person who made the change and other necessarily remarks regarding the changes. Revision log is a piece of content you can add to a document to record all these information. With a revision log, you fill in the revision detail as well as to add/remove columns to suit the requirement of your team. To insert a table of contents:
- Select the content block where you want to insert a revision log beforehand.
- Click on the button on the document’s toolbar and then select Revision Log from the drop down menu.
- To enter a revision, double click on the cells and enter the values one by one.
- If you want to insert more rows or columns, right click on the revision log and select Insert Row or Insert Column from the popup menu.
