1. Home
  2. Docs
  3. Chapter 23. Document Production
  4. 4. Doc. Composer Fill-in-Doc mode
  5. Introducing Doc. Composer’s Fill-in-Doc mode
Typically, a project documentation or report is a combination of background information like project goal, scope and constraints, and design details like use case details, database design, process design, etc. The Fill-in Doc mode of Doc. Composer is designed to help you “fill-in” the design details of your documentation. As an overview, Fill-in Doc works in this way:
  1. You write your project documentation in Microsoft Word.
  2. Place some special fields to the parts that requires the insertion of design details.
  3. Load the document into Doc. Composer
  4. Export a document. Doc. Composer analyze the special fields in your document and replace them with actual project content.
