When you are ready for producing the final document, click Generate at the bottom right corner of the document preview. Enter the filename of the document and confirm. A complete document file will then be generated.
Chapter 23. Document Production
- 1. Project Publisher
- 2. Introducing Doc. Composer
- 3. Doc. Composer Build-from-Scratch mode
- Introducing Doc. Composer’s Build-from-Scratch mode
- Creating a document
- Developing a document using element template
- Working with content block
- Using Loop
- Adding custom text
- Adding image
- Adding table
- Adding page break
- Using section
- Adding table of contents
- Adding revision log
- Adding cover page
- Various page display options
- Keeping your document updated
- Writing your element template
- Exporting a document
- Managing element templates in team environment
- Managing styles in team environment
- 4. Doc. Composer Fill-in-Doc mode
- Introducing Doc. Composer’s Fill-in-Doc mode
- What is Doc Base?
- What is Doc Field
- Creating a Fill-in Doc
- Touching-up a document
- Previewing a document
- Generating a document
- Doc Fields in detail
- Querying diagrams
- Querying model elements
- Querying diagram elements
- Using custom text
- Working with table
- Managing Doc Templates in team environment
- 5. Writing Doc. Composer element templates
- What is Doc. Composer Template Language?
- Beginning of template
- Text and Property
- Looping (Non Connector)
- Looping (Connector)
- Sorting in Loop
- Conditional Expression
- Working with Table
- Working with Image
- Working with Break
- Working with other DCTL Constructs
- Reusing Template with Inline or Reference
- Using variables
- DCTL Examples
- Supported Diagram Types
- Home
- Docs
- Chapter 23. Document Production
