<ForEach property="stepContainers">
<Property property="name"/>
<TableBlock>
<FlowOfEventIterationBlock> <!-- Walk through each step (row) in a scenario -->
<TableRow>
<TableCell>
<FlowOfEventIndent/> <!-- Apply proper indentation to the current step. You don't have to specify the level of indentation. It's automatically done for you -->
<Property property="index" foreColor="#848284" style="Table Contents"/> <!-- The step number. We set its foreColor to a lighter one to make it looks like how it looks in Visual Paradigm -->
<Text style="Table Contents"> </Text>
<ValueChecker property="type" operator="not equals" value="">
<ValueChecker property="type" operator="not equals" value="system">
<Property property="type" foreColor="#00B200" style="Table Contents"/> <!-- @type here refers to 'control labels' like if, then, elseif -->
</ValueChecker>
<ValueChecker property="type" operator="equals" value="system">
<Property property="type" foreColor="#CA6400" style="Table Contents"/> <!-- @type here refers to SYSTEM -->
</ValueChecker>
</ValueChecker>
<Property property="name" style="Table Contents"/> <!-- The content of step -->
</TableCell>
</TableRow>
</FlowOfEventIterationBlock>
</TableBlock>
</ForEach>
Working with Sub-Diagrams
<HasSubDiagramChecker>
<!-- Name of all sub-diagrams -->
<ForEachSubDiagram>
<Property property="name" />
<ParagraphBreak/>
</ForEachSubDiagram >
<!-- Name of all sub-BPD -->
<ForEachSubDiagram diagramType="BusinessProcessDiagram">
<ParagraphBreak/>
</HasSubDiagramChecker>
Working with References
<!-- Output the name of all Use Case reference -->
<HasValueChecker property="references">
<ForEach property="references">
<ValueChecker property="type" operator="equals" value="Model Element">
<ModelElementProperty property="url">
<ValueChecker property="modelType" operator="equals" value="UseCase">
</ValueChecker>
</ModelElementProperty>
</ValueChecker>
</ForEach>
</HasValueChecker>
<!-- Output the name of all model elements that are referencing the querying element as 'Model Element Reference' -->
<HasValueChecker property="modelElementReferencedBys">
<ForEach property="modelElementReferencedBys">
</ForEach>
</HasValueChecker>
<!-- Output the name of all model elements that are referencing the querying element as 'Shape Reference' -->
<HasValueChecker property="viewReferencedBys">
<ForEach property="viewReferencedBys">
</ForEach>
</HasValueChecker>
Working with Stereotypes and Tagged Values
<!-- Output the name of all assigned stereotypes -->
<HasValueChecker property="stereotypes">
<ForEach property="stereotypes" ignoreLastSeparator="true">
<Text><<</Text>
<Text>>></Text>
</ForEach>
</HasValueChecker>
<ParagraphBreak/>
<!-- Output the name of tagged values added -->
<HasValueChecker property="taggedValues">
<ModelElementProperty property="taggedValues">
<HasChildElementChecker modelType="TaggedValue">
<IterationBlock modelType="TaggedValue">
<Text> - </Text>
<Property property="value" />
</IterationBlock>
</HasChildElementChecker>
</HasValueChecker>
Working with Table Records of Entity
<!-- Check if an entity (i.e. DBTable) has record specified -->
<HasValueChecker property="records">
<TableBlock>
<!-- Create a header row that shows the columns' name in each cell -->
<TableRow>
<IterationBlock modelType = "DBColumn">
<TableCell>
</TableCell>
</IterationBlock>
</TableRow>
<!-- Create one row for each record -->
<ModelElementProperty property="records">
<IterationBlock modelType = "EntityRecord">
<TableRow>
<IterationBlock modelType = "EntityRecordCell">
<TableCell>
<!-- Output the value directly if it's a general column -->
<!-- Use the following method to output the value if it's a FK -->
<HasValueChecker property="value" flag="true">
<ModelElementProperty property="value">
</HasValueChecker>
</TableCell>
</IterationBlock>
</TableRow>
</IterationBlock>
</TableBlock>
</HasValueChecker>
Working with Working Procedures of BPMN Task/Sub-Process
<!-- Check if a BPMN task/sub-process has working procedure entered -->
<HasValueChecker property="bpProcedures">
<!-- Retrieve the procedure steps -->
<ForEach property="bpProcedures">
<Property property="name" style="@heading"/>
<ParagraphBreak/>
<!-- Retrieve the steps in the querying procedure set -->
<ForEach property="bpProcedureSteps">
<ParagraphBreak/>
</ForEach>
</ForEach>
</HasValueChecker>
<!-- Check if the querying element has transition, either from/to -->
<HasValueChecker property="Traceability">
<Text>Traceability detected.</Text>
<ParagraphBreak/>
</HasValueChecker>
<ParagraphBreak/>
<!-- List out the Transit From elements -->
<Text isBold="true">Transit From:</Text>
<ParagraphBreak/>
<ForEach property="transitFrom">
<ParagraphBreak/>
</ForEach>
<ParagraphBreak/>
<!-- List out the Transit To elements -->
<Text isBold="true">Transit To:</Text>
<ParagraphBreak/>
<ForEach property="transitTo">
<ParagraphBreak/>
</ForEach>
<ParagraphBreak/>
<!-- List out the Transit From diagrams -->
<Text isBold="true">Transit From (Diagram):</Text>
<ParagraphBreak/>
<ForEachDiagram property="transitFrom">
<ParagraphBreak/>
</ForEachDiagram>
<ParagraphBreak/>
<!-- List out the Transit To diagrams -->
<Text isBold="true">Transit To (Diagram):</Text>
<ParagraphBreak/>
<ForEachDiagram property="transitTo">
<ParagraphBreak/>
</ForEachDiagram>
<ParagraphBreak/>
Working with InstanceSpecification in an Object Diagram
<!-- Print the description of instanceSpecifications and their classifiers, in a given object diagram-->
<DiagramBaseInitiationBlock>
<IterationBlock modelType="InstanceSpecification">
<!-- Name of instance (in ${instance_name} : ${classifier} format)-->
<Text> : </Text>
<HasValueChecker property="classifiers">
<ForEach property="classifiers">
</ForEach>
</HasValueChecker>
<!-- Description of class-->
<ParagraphBreak/>
<Text isBold="true">Description of classifier: </Text>
<Property property="description" />
</ForEach>
</HasValueChecker>
<!-- Description of instance-->
<ParagraphBreak/>
<Text isBold="true">Description of instance: </Text>
<Property property="description"/>
<ParagraphBreak/>
<ParagraphBreak/>
</IterationBlock>
</DiagramBaseInitiationBlock>
