<ForEachSimpleRelationship>
Retrieve SimpleRelationship elements from model element or connector from diagram element.
The following table lists the available attributes of <ForEachSimpleRelationship>.
<ForEachRelationshipEnd>Retrieve the from or to end of an association.The following table lists the available attributes of <ForEachRelationshipEnd>.
| Name | Description/Usage | Required? |
| modelType : string | Filter relationship by specified model element type (e.g. Generalization). Note that not all kind of relationship belongs to simple relationship. Here are the possible types of simple relationship:
Abstraction, ActivityObjectFlow, AnalysisComposition, AnalysisDiagramTransitor, AnalysisParentChild, AnalysisReference, AnalysisRelationship, AnalysisSubDiagram, AnalysisTransitor, AnalysisUsed, AnalysisView, Anchor, ArchiMateAccess, ArchiMateAggregation, ArchiMateAssignment, ArchiMateAssociation, ArchiMateCommunicationPath, ArchiMateFlow, ArchiMateNetwork, ArchiMateProvide, ArchiMateRealization, ArchiMateRequire, ArchiMateSpecialization, ArchiMateTriggering, ArchiMateUsedBy, AssociationClass, BPAssociation, BPDataAssociation, BPMessageFlow, BPSequenceFlow, BindingDependency, BusinessRuleAssociation, Constraint, ControlFlow, ConversationLink, DBForeignKey, DFDataFlow, Dependency, Deployment, EPCControlFlow, EPCInformationFlow, EPCOrganizationUnitAssignment, ExceptionHandler, Extend, Generalization, GenericConnector, GlossaryFactTypeAssociation, Include, InteractionDiagramDurationConstraint, Link, MindConnector, MindLink, OCLine, ObjectFlow, PMProcessLink, Permission, RQRefine, RQTrace, Realization, RequirementDerive, Satisfy, Transition, Transition2, Usage, Verify |
Optional |
| modelTypes : string | Filter relationships by modelTypes. If @modelType is defined, @modelTypes will be ignored. | Optional |
| direction
{all | from | to} |
Filter relationship by direction. | Optional |
| ignoreLastSeparator : boolean = false | Ignore the break for the last element of current for-each loop.
Break can be <ParagraphBreak> or <StaticText @content= “\n” or “,”>. |
Optional |
| breakString : string | Insert a string between model elements of current for-each. | Optional |
| modelType : string | Filter relationship end by specific model element type. | Optional |
| endPointer
{all | from | to | both | self | other} |
Filter relationship ends based on the way they are attached to the querying element. For example, if ‘from’ is specified, only relationships that take the querying element as the source (i.e. from end) will be chosen. | Optional |
| ignoreLastSeparator : boolean | Ignore the break for the last element of current for-each loop. | Optional |
