1. Home
  2. Docs
  3. Chapter 23. Document Prod...
  4. 5. Writing Doc. Composer ...
  5. Using variables
Using variables
To favor template reusability, some of the template elements support the use of variable. User who produce a document with a template that has variable defined will need to specify the value of the variable in runtime to generate the outcome he/she expect.
How does it work?
Let’s take a look at the following example:
A template List of Operations has been written for element type ‘Class’ to output a list of operation names from a given class. Let’s say we want to output only operations with a specific visibility to be decided by the person who produce the final document. This is the content of the template:
<?xml version="1.0" encoding="UTF-8"?>
<ElementBaseInitiationBlock>
    <Text>List of operations:</Text>
    <ParagraphBreak/>
    <IterationBlock modelType="Operation">
        <ValueChecker property="visibility" operator="equals" value="${oper-visibility}">
            <Property property="name"></Property>
            <ParagraphBreak/>
        </ValueChecker>
    </IterationBlock>
</ElementBaseInitiationBlock>
Pay attention to @value in <ValueChecker>. Instead of having the value of visibility hardcoded in the template, a variable ${oper-visibility} is used.
In Doc. Composer, the person who want to output a document with the template will use the template as usual by dragging it onto the document.
To use a template in document
After that, he/she has to specify the value of the variable, which is, in this case the visibility of operation expected. To do this, right click on the content block on the document and select Configure Local Variables… from the popup menu.
Configure local variable
In the Configure Local Variables window, enter the value of the variable. In this case, public is entered. This means that the variable ${oper-visibility} will be replaced by the text ‘public’ when producing content for this block.
To set the value of visibility
When finished, click OK to confirm.
Besides entering the value, there is an option Follow Global in the configuration window. The value of variable can be set locally and globally. Values set locally will be effective within a specific block of content, while values set globally will be effective to the entire document. To make a variable follows global setting, simply check Follow Global.
The Follow Global option
To enter the value of variables globally, click on the Configure Global Variables… button in the toolbar of Doc. Composer and enter the value in the Configure Global Variables window.
Why variable?
To use variable instead of hard-coding a value gives you the following benefits.
Unifying the outcome
Instead of writing and maintaining a set of similar templates, you just need to write a single template only. This ensures the consistency of similar content since they all come from a single source.
Let the ‘user’ of template decide what to output
The use of variable allows the person who produce the document decide what to output, instead of forcing the editor of template to make the decision when writing the template, which is sometimes impractical.
Elements that supports the use of variable
The following table lists the elements and the attributes that support the use of variable.
Element Attribute
TableBlock tableStyle
Text style, href
Property style
ForEachDiagram diagramType
ForEachSubDiagram diagramType
ForEachOwnerDiagram diagramType
HasDiagramChecker diagramType
HasSubDiagramChecker diagramType
HasOwnerDiagramsChecker diagramType
HasChildElementChecker stereotypes
HasRelationshipChecker modelTypes
HasParentModelChecker modelType
HasValueChecker stereotypes, modelType, name
IterationBlock stereotypes, name, modelTypes
ValueChecker value
