Chapter 27. Export and Import
⌘K
  1. Home
  2. Docs
  3. Chapter 27. Export and Im...
  4. 5. Command-line Interface
  5. Exporting and importing XMI with command
Visual Paradigm supports interoperability with XMI file, a standard made for data exchange. You can export project data to an XMI, edit it externally with other softwares that accepts XMI. In this chapter, you will see how to export and import XMI through the command line interface.
Exporting XMI
To export XMI from a project through command line:
  1. Browse the scripts folder under the Visual Paradigm installation directory. For Mac users, you can find the scripts folder in the Visual Paradigm package by right clicking on it and then selecting Show Package Contents. Then look in Contents\Resources\app\scripts for the scripts folder.
  2. Start the command prompt.
  3. Execute the script by supplying the required parameters. For example:
    ExportXMI -project C:\Demo\Demo.vpp -out C:\Demo\Output\Sample.xmi -type 2.1
    Parameter Description Example
    -project Project path C:\Demo\Demo.vpp
    -out The filepath of XMI file C:\Demo\Output\sample.xmi
    -type [optional] Version of XMI. Unless specified, the lastly generated version will be selected. Here are the possible options:
    • 2.1
    • 2.1UML2
    2.1
    -encoding [optional] Encoding of XMI file
    -upgrade-project [optional] Ensures the project runs on the latest Visual Paradigm version. If included, outdated projects are auto-converted. If omitted, users are prompted to convert.
Importing XMI
To import XMI to a project through command line:
    ImportXMI -project C:\Demo\Demo.vpp -file C:\Demo\input\sample.xmi
    -file The filepath of the XMI file to import C:\Demo\input\sample.xmi
