Chapter 27. Export and Import
⌘K
  1. Home
  2. Docs
  3. Chapter 27. Export and Im...
  4. 5. Command-line Interface
  5. Java synchronization with command
To perform synchronization between model and Java code through command line:
  1. Browse the scripts folder under the Visual Paradigm installation directory. For Mac users, you can find the scripts folder in the Visual Paradigm package by right clicking on it and then selecting Show Package Contents. Then look in Contents\Resources\app\scripts for the scripts folder.
  2. Start the command prompt.
  3. Execute the script by supplying the required parameters. For example:
    JavaCodeSync -project C:\Demo\Demo.vpp -src C:\Demo\MyProject\src -generate
    Parameter Description Example
    -project Project path C:\Demo\Demo.vpp
    -src The folder path of the source file C:\Demo\Output\src
    -generate | -reverse Action to perform. Include -generate to indicate the update of code from model. Include -reverse to indicate the update of model from code. -generate
    -upgrade-project [optional] Ensures the project runs on the latest Visual Paradigm version. If included, outdated projects are auto-converted. If omitted, users are prompted to convert.
