Chapter 36. NAF Tool
⌘K
  1. Home
  2. Docs
  3. Chapter 36. NAF Tool
  4. 2. Concepts Viewpoints
  5. C5 – Effects
C5 – Effects
The purpose of the C5 Viewpoint is to describe the operational effect of the capabilities, activities, and services according to the expected goals. The C5 Viewpoint is a high-level description that should be easily understood by non-technical readers.
Usage
The intended usage of the C5 includes:
  • Characterization of the expected results capabilities, positive or negative.
  • Analysis of cumulative effects.
  • Analysis of persistence of the effects.
  • Tracing the operational states and modes with regards to the effects.
Creating an Effects diagram
To create an Effects diagram:
  1. Click on Effects in the Action Artifact area, and then select Create New Diagram.
  2. Type the diagram name and press Enter.
  3. A blank diagram is created and you can start constructing the view by defining AchievedEffects (A dependency relationship that exists between an ActualState of an element that attempts to achieve a DesiredEffect and an Achiever) and DesiredEffects (A dependency relationship relating the Desirer to an ActualState).
NATO NAF Example: Effects
