Chapter 36. NAF Tool
⌘K
  1. Home
  2. Docs
  3. Chapter 36. NAF Tool
  4. 4. Logical Specifications...
  5. L5 – Logical States
L5 – Logical States
The L5 Viewpoint specifies the typical states a node may have and the possible transitions between those states (i.e. changes of state). Triggers for state changes may also be defined. Actions may be associated with a given state or with the transition between states in response to stimuli (e.g. triggers and events).
Usage
The intended usage of the L5 includes:
  • Analysis of business events.
  • Behavioural analysis.
  • Identification of constraints.
Creating a Logical States diagram
To create a Logical States diagram:
  1. Click on Logical States in the Action Artifact area, and then select Create New Diagram.
  2. You are creating a table for managing the state diagrams. Type a name for the table. You can create multiple tables based on different contexts (e.g. by phases, purposes, etc).
  3. This opens a table where you can create and manage state diagrams. Click on New Logical State Machines Definition above the table to create a new row.
  4. Under the first column, select the context to create a state diagram, which can be an OperationalPerformer or OperationalArchitecture.
  5. Under the second column, create the state diagram(s). The diagram created will be added to the selected context element as a sub-diagram.
NATO NAF Example: Logical States
