Chapter 31. TOGAF ADM Guide-Through
⌘K
  1. Home
  2. Docs
  3. Chapter 31. TOGAF ADM Guide-Through
TOGAF was developed starting 1995 by The Open Group, based on DoD’s TAFIM. As of 2016, The Open Group reports that TOGAF is employed by 80% of Global 50 companies and 60% of Fortune 500 companies.
What is TOGAF ADM?
The TOGAF ADM is the result of continuous contributions from a large number of architecture practitioners. It describes a method for developing an enterprise architecture, and forms the core of TOGAF. It integrates elements of TOGAF described in this document as well as other available architectural assets, to meet the business and IT needs of an organization. It is specifically designed to address enterprise’s business and IT needs by providing:
  • A set of architecture views (business, data, applications, technology)
  • Guidelines on tools for architecture development
  • A set of recommended deliverables
  • Linkages to practical case studies
  • A Method for managing requirements
What are the Phases of the ADM?
The ADM consists of a number of phases that cycle through a range of architecture domains that enable the architect to ensure that a complex set of requirements is adequately addressed. The basic structure of the ADM is shown in Figure below:
Image result for togaf adm visual paradigm
The Architecture Development Method Cycle
The ADM is applied iteratively throughout the entire process, between phases, and within them. Throughout the ADM cycle, there should be frequent validation of results against the original requirements, both those for the whole ADM cycle, and those for the particular phase of the process. Such validation should reconsider scope, detail, schedules, and milestones. Each phase should consider assets produced from previous iterations of the process and external assets from the marketplace, such as other frameworks or models.
  • The ADM supports the concept of iteration at three levels:
    Cycling around the ADM: The ADM is presented in a circular manner indicating that the completion of one phase of architecture work directly feeds into subsequent phases of architecture work.
  • Iterating between phases: TOGAF describes the concept of iterating across phases (e.g., returning to Business Architecture on completion of Technology Architecture).
  • Cycling around a single phase: TOGAF supports repeated execution of the activities within a single ADM phase as a technique for elaborating architectural content.
Summary of TOGAF ADM
ADM Phase Activity
Preliminary Phase: Framework & Principles Prepare the organization for successful TOGAF architecture projects; define architecture principles; define framework and tools
Requirements Management Ensure that every stage of a TOGAF project is based on and validates business requirements
Phase A: Architecture Vision Set the scope, constraints, and expectations for a TOGAF project; create Vision; define stakeholders; validate the business context and create the Statement of Architecture Work; obtain approvals
Phase B: Business Architecture
Phase C: Information Systems Architectures
Phase D: Technology Architecture
Develop architectures at three levels:
  1. Business
  2. Information Systems
  3. Technology
In each case develop the Baseline (“as is”) and Target (“to be”) Architecture and analyze gaps
Phase E: Opportunities & Solutions Evaluate and select among the implementation options identified in the target architectures; identify major implementation projects
Phase F: Migration Planning Analyze cost benefits and risk; develop prioritized list of projects to form basis of implementation and migration plan
Phase G: Implementation Governance Prepare and issue Architecture Contracts (Implementation Governance Board); ensure that the implementation project conforms to the architecture
Phase H: Architecture Change Management Provide continual monitoring to ensure that the architecture responds to the needs of the enterprise
Articles
